Set up help
Set up help
New at this and have what is most likely a set up mistake. I think l am set up for a 1 to 1 drawing scale but when I put dimensions in the are way big. Like should be 16 inches but shows 85 feet.
Re: Set up help
This is a screen shot of what is actually happening.
- Capture 1.JPG (16.43 KiB) Viewed 3997 times
Re: Set up help
What is your drawing unit?
Is the drawing drawn in 1:1?
Re: Set up help
When you launch the dim tools an option bar pops up. Is the chosen scale 1"=1"?
Re: Set up help
In addition, you might want to check that your snap is on and that snap is set to .1 or some other preferred value. Otherwise it's hit or miss.
