Whiteout (Solved)
Whiteout (Solved)
I need to insert some text over some linework and images. In some other CAD packages there is a whiteout function that allows this to happen. Is it possible in QCAD?
seasdes
QCAD Pro V3.27.8
User since 2021
W10
QCAD Pro V3.27.8
User since 2021
W10
Re: Whiteout
QCAD does not have a whiteout function. This said, you can use a solid hatch to have a similar effect.
Re: Whiteout (Solved)
Hi
This is a bit of a hack but it works
I draw white on a black screen and I thought I'd share this with you all...
It's just a white image but you can change its size width & height as you like, I hope this comes as a handy tip..
Just make sure Modify > Draw Order > Bring to Front is set or use hotkeys MF
And once you have in your drawing you can cut and paste as you like..
The Whiteout.png file.. Cheers
And Why not have a round one too
That can be made oval or any size you like..
Thanks John. A great tip. And the image size can be reshaped by dragging the handles of the image.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
QCAD Pro V3.27.8
User since 2021
W10
Thanks seasdes
Here's another whiteout, square with radius corners...
