Hi I am trying to open a dxf file in VB6 with command line. Sometimes it open correctrly the file, but most of times I get this error (image attached)
I have tried by several calls, for example:
QCAD.exe "O:\OF20210302065\Procesado\File.dxf"
Any suggestion?
Open dxf from command line
- open.png (4.35 KiB) Viewed 2119 times
Re: Open dxf from command line
The call is correct. Please make sure QCAD has access to the file (permissions) and the file is there for the whole duration of opening it. Locked files can also be a problem under Windows.
Before the call I use edrawings to preview the file i a form. Maybe it is locking the file. I will try avoid it or make a copy. thanks
