[solved] convert dxf from custom CRS via dwgmapconvert
pechnik
Post by pechnik » Thu Mar 25, 2021 8:58 am
I need to generate map tiles from dxf files. This dxf files contains data in custom CRS(it does not represented in known EPSG projection).
Here(changelog 3.24.3 (2020/03/17)) i found that we can pass custom projection in JSON configuration file. But there is no examples how to do it.
Re: convert dxf from custom CRS via dwgmapconvert
Post by andrew » Thu Mar 25, 2021 4:03 pm
That method has been dropped as QCAD now uses the PROJ library which supports lots of projections.
Do you know the ESRI WKT (well known text) for your projection? If so, you should be able to pass that to dwgmapconvert instead of the name/code. ESRI WKT looks for example like this:
PROJCS["CH1903+_LV95",GEOGCS["GCS_CH1903+",DATUM["D_CH1903+",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Hotine_Oblique_Mercator_Azimuth_Center"],PARAMETER["latitude_of_center",46.95240555555556],PARAMETER["longitude_of_center",7.439583333333333],PARAMETER["azimuth",90],PARAMETER["scale_factor",1],PARAMETER["false_easting",2600000],PARAMETER["false_northing",1200000],UNIT["Meter",1]]
So your command could look for example like this:
./dwgmapconvert -segment-length=0.5 -crs-in=EPSG:3857 -crs-out=PROJCS["CH190.+_LV95",GEOGCS["GCS_CH1903+",DATUM["D_CH1903+",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Hotine_Oblique_Mercator_Azimuth_Center"],PARAMETER["latitude_of_center",46.95240555555556],PARAMETER["longitude_of_center",7.439583333333333],PARAMETER["azimuth",90],PARAMETER["scale_factor",1],PARAMETER["false_easting",2600000],PARAMETER["false_northing",1200000],UNIT["Meter",1]] -f -o epsg2056.dxf epsg3857.dxf
pechnik
Post by pechnik » Fri Mar 26, 2021 12:10 pm
Yes, with ESRI WKT string it works fine!
