how do i increase export size limits ?
cyhkimo
Post by cyhkimo » Thu May 06, 2021 3:57 am
my dwg file : W*H=6490*7680 um, i want to scale 4 to show 0.25um diff.
[root@CADKIT qcad-3.26.1-pro-linux-qt4-x86_64]# ./dwg2bmp -f -r 4 -o /root/A3T4GF40B_20210506.bmp /root/A3T4GF40B_20210506.dxf
QCAD version 3.26.1
Debug: calling odInitialize
Converting
to : /root/A3T4GF40B_20210506.bmp
Debug: invalid image size
Error: cannot save file: /root/A3T4GF40B_20210506.bmp
Error: Invalid image size (width x height must be less than 5.36871e+08)
Re: how do i increase export size limits ?
Post by andrew » Thu May 06, 2021 2:51 pm
Unfortunately, there's no way around that limit. It is imposed by Qt, the toolkit used by QCAD.
A possible workaround might be to export to PDF and convert the PDF to a bitmap using a separate tool such as imagemagick (not included in QCAD).
