[Answered/Solved] Selective layers constraint when scaling
Hello again. I hope I can ask this correctly.
I want to create a "template" window block. However, windows do change dimension, normally the frame remaining a fixed dimension.
Is there a way to re-dimension a entity/block but keep certain entities in that layer/block constrained to the dimensions it was created with?
This will extend to child layers and blocks.
I think the x/y/parent constraints make sense (constrain layer based on parent constraints), but the Anchor constraint would be to keep layer in exact position during a scale function???
Attached is a sample. I also attach a proposed layer create/edit form with constraint options - just an initial thought.
Am I missing something? I have searched, but no luck yet.
Best
Best
Windows 10
Re: selective layers constraint when scaling
Maybe you should consider to use the "Stretch" tool instead of the "Scale" tool. Just an initial thought. Give it a try ...
https://www.qcad.org/doc/qcad/latest/re ... ro_en.html
Thank you. I think that might not be what I'm asking, but I'll try. I'm trying to constrain any stretching on certain layers/entities in a block/layer. However, I'm off the the drawing to play with that now. Nope..
Very best
Very best
Windows 10
- petevick
Would locking certain layers give you what you want ?
Pete Vickerstaff
Locked layers don't update so nothing of those is moved then.
I think it is, the catch is: What is selected and how the 4 references are picked.
- Select all what to 'Strech' AND all what to 'Move'
Box what to 'Move'
Pick 2 know references
I know, but it works for me with carfully picking references.
Many thanks guys... but I think we're at an impasse. Unless there's a completely different train of thought. I am specifically wanting to "lock" a specific layer dimensions and keep ratio of position with an adjustable (scalable/moveable) entity.
Attached should be clearer?
I want to keep the red bits the SAME size, but stretch the BLUE bits keeping the red BITS same size but moved to new position locked onto the BLUE bits. Accomplish this with a block where certain entities are fixed to a reference point of another entity but doesn't change dimension(size). Of 2 entities, one entity is unchangeable (dimension "locked") and is fixed onto another changeable entity by its relative position to that changeable entity.
Thanks CVH - I don't understand "Box what to 'Move'"
Cheers and best. Perhaps my explanation is not written in proper English. I do understand language differences
Very best
Very best
Windows 10
Stretch requires 4 reference points
- First corner
Second corner
Reference point
Target point
Entities that cross the box are stretched as a rubber band.
Entities that are inside the box are simply moved.
The tool acts on all inside and all that cross.
Or can act only on those that where selected upfront.
In your second example, high, the glass and the frames should be separate things to be functional.
Also, I am referring to entities! It doesn't work as a block as those are considered to be 1 thing each.
The glass could be a simple polyline, L & R frame can be blocks.
Maybe this works also in the 'Edit Block In-place' mode?
(Can't tell you that, as scripter I'll never use that anymore)
BTW: Are you aware that the glass in the lower part is slanted a minute bit?
0.021198° ...Used OG-OC?
Yeah, I saw that, - working on motorcycle and trying to conjure correct words and an example are 3 things... being male, it's obvious I'm not capable of chewing gum and walking simultaneously
I'll persevere... I think I'll be forced to make several windows/blocks, each of different sizes. Sorta negates the usefulness of a library.
Best
Best
Windows 10
- ryancousins
This is probably not the direction you want to go but have you thought about a parametric modeler to set this up and then export a DXF to bring in to QCAD? Here is a quick example based loosely on your example, using OpenSCAD.
- pic03.png (118.77 KiB) Viewed 6642 times
- pic02.png (27.82 KiB) Viewed 6642 times
- pic01.png (36.32 KiB) Viewed 6642 times
I would only support this idea when we are talking about just a handful of blocks (3-5 or so). Other than that I would stick to the stretch tool.
Why? You have only to deal with ONE block. You can stretch this block to ANY needed measurement. After you got use to the procedure it is a piece of cake!
What can you do with this ONE block?
1. use it as it is.
2. insert it and modify the size as needed like:
A) fit in with snap points ...
B) Extend it with a specific value. Example shows how to stretch it 150 longer ...
... or C) lengthen it to a total value. Example shows how to stretch it to a total of 700.
Ryan - thank you. You are correct, not really where I wanted to go and way over my head . However, your time is most appreciated.
CVH - Now the lightbulb is on! I see what you mean about the box. I just never took the stretch tool to the outer limits.
Husky - you need to box up all those wonderful GIFs and videos and publish them! I can see I was barking up the wrong tree, somewhat. I can use Library (I think) and not blocks. Your short demo opened my eyes to essentially exactly what I was asking. As they say, a picture is worth a thousand words - and you figured what I was asking (amazing! - my wife can't!) I'm even impressed that this method (stretch/boxing) even adjusts dimensions. Perfect so far.
I'm going to change subject to "Answered/Solved" if that's okay.
(As an aside Husky, what screen/keyboard/mouse recorder do you use? Very easy to follow.)
Very best
Very best
Windows 10
- ryancousins
