WINDOWS 10 / QCAD PROFESSIONAL
Hi, please,
when i import files, like .dwgs ones, the lines get very thick. I can't even see the whole draw, like the image attached.
How do i change to normal lines?
Thank you.
Thick lines when import files
- Screenshot_1.png (127.79 KiB) Viewed 2422 times
Re: Thick lines when import files
if possible please attach the drawing to your post. That will speed up the search for the issue. Thanks.
Please adjust your default line weight under:
Edit > Application Preferences > Graphics View > Appearance > Default lineweight
