Hatch Origin
seasdes
Senior Member
Hatch Origin
Post by seasdes » Mon Jun 07, 2021 2:44 am
The origin of a hatch appears to be the origin of the drawing.
Is it possible to define the origin of a hatch on a per instance basis rather than using the drawing origin?
I often have a need to do this in floor plans and elevations for tiles and bricks.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Hatch Origin
Post by Husky » Mon Jun 07, 2021 2:50 am
You can select the hatch and use the Property Editor to change the Origin of that hatch:
seasdes
Senior Member
Re: Hatch Origin
Post by seasdes » Mon Jun 07, 2021 2:57 am
Thanks Husky. For some reason I thought that changing the origin of one hatch affected all other. My bad.
Now, How can I snap to parts of a hatch so that I can measure how much I need to change the origin of the hatch?
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Hatch Origin
Post by John Hyslop » Mon Jun 07, 2021 5:40 am
Hi Seasdes
Unfortunately the ability to measure hatch segments on hatch borders were removed a few versions back, you can however explode the hatch add dimensions or measure distances, take notes then undo explode and adjust the hatch origin accordingly..as Husky noted above..
Hope this helps.
Re: Hatch Origin
Post by Husky » Mon Jun 07, 2021 7:05 am
Is exploding the hatch necessary or not has to be determine with a test hatch. For that draw a rectangle over the absolute 0 point (marked by the QCAD software with a red cross). Put in the hatch, something like this ...
The red cross shows where the hatch starts it geometry. Is that useful for you? Great - then there is no need to explode the hatch. Take with an Info tool (IO) a x/y measurement at the point where the hatch has to start in your drawing, create the hatch and use the x/y measurement as the new hatch origin.
BTW: My test hatch pattern ("Tiles" was created with the Basic Hatch Tool V3.0.1 from J.M.Hyslop. Maybe something what you can use for your projecs. It is free Software .... e_surprised
viewtopic.php?f=30&t=6944&p=33566#p33566
seasdes
Senior Member
Re: Hatch Origin
Post by seasdes » Mon Jun 07, 2021 8:47 am
Thanks John & Husky
I have tested both methods and they both work for me. Husky's method may be a bit quicker though as long as I increase the Linear dimension precision from 0 decimal places to say 4 decimal places. Then change back to zero decimal places when finished.
Yes I have downloaded the Basic Hatch Maker Tool. I will find a lot of use for this great tool. Thanks John.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Hatch Origin
Post by John Hyslop » Mon Jun 07, 2021 10:52 am
Hi Husky
I'll be using your method in future e_surprised , very clever..
Thanks for the referral also..
I hope you get some good use out of BHT Seasdes..
