Concave Hull Function?
Dauu
Post by Dauu » Sat Jun 26, 2021 8:56 pm
I have set of many points .
Is there any concave hull function or plugin instead of manual connection with line tool? :(
Re: Concave Hull Function?
Post by Husky » Sat Jun 26, 2021 9:18 pm
- Indicate the operating system you are using and the version thereof (e.g. Windows 10 32bit, Windows 8.1 64bit, Ubuntu 14.2 64bit, macOS 10.12, etc.)
- Indicate the exact version of QCAD you are using (see "Help" > "About" or "QCAD" > "About QCAD" or indicate the name of the file you have downloaded and installed)
- Attach original drawing files (DXF, DWG, ...) if appropriate
- Attach exported files (SVG, PNG, PDF, G-Code, ...) if appropriate
- Include screenshots if appropriate
- If there is an error message, indicate the exact message or include a screenshot of the message
- Indicate what post processor you are using
Post by andrew » Sat Jun 26, 2021 9:22 pm
Not as a ready-made tool, but you can do it with a bit of scripting in the script shell (Misc > Development > Script Shell).
First select only the points, then paste this simple code in to the script shell command prompt:
var doc = getDocument();
var ids = doc.querySelectedEntities();
var points = [];
for (var i=0; i<ids.length; i++) { var e=doc.queryEntity(ids[i]); points.push(e.getPosition()); }
var pl = RPolygonHull.getConcaveHull(points, 0.1);
addShape(pl);
Notes:
- There is no error handling in this code and you will get an exception if you select other entities than points.
- 0.1 is the concavity (smaller is more detailed, larger less detailed or even convex for very large numbers).
- This works in QCAD Professional or QCAD/CAM
