How do I (or is it possible) to set dimension label precision for individual dimensions?
i.e. I have set global precision to one place (0.0 and Show trailing zeros)
and that works fine for me for vast majority of the drawing,
but occasionally for an individual dimension I would like to change it to two places (0.00).
label precision
label precision
QCad Pro
elementary OS & Windows 10 Pro
Re: label precision
Dimensions settings are global per drawing.
When only occasionally then you could edit the label text manually to anything (fixed) you like.
Re: label precision
Thanks,
I was hoping that I was missing something
Sounds like I wasn't...
I already use the manual method for dual (metric/imperial) dimensions.
In this scenario metric dim is system driven and imperial is added manually (where needed).
I suppose you can't have everything
What about "Custom properties" BTW?
p.s. I have made suggestion here:
https://qcad.org/rsforum/viewtopic.php?f=31&t=8699
QCad Pro
