I receive architect's plans with blocks containing area and height displays of rooms in the following form:
area : \A1 ... m \A1 ²
height : \A1 ... m \A1
https://imgur.com/mqrID7Y
see also attached file
I can edit the blocks and remove the "\A1" for each label, but it is tedious.
Is there a way to remove these "\A1" in a more automatic way ?
Thank you in advance for your help
Phil
Versions
QCAD version: 3.26.4.0
Date: Jun 4 2021
Qt version: 5.14.2
Compiler version: gcc 5.4.0
Build date: Jun 4 2021
Architecture: x86_64
OS: Linux
OS version: 20.04
[SOLVED] changing the display of room dimensions in blocks
- __Rez+1.dwg
- (196.6 KiB) Downloaded 288 times
Re: changing the display of room dimensions in blocks
Menu .. Edit .. Find/Replace (RP) finds only 44 occurrences.
I had to revert because not all "\A1" where replaced.
QCAD saves dxf files textual ...
Saved as dxf one can find 110 times "\A1;" or 166 times "\A1"
Looks like a specific formatting escape.
E.g. Notepad++
Replacing first the "\A1;" by nothing and then the "\A1" by nothing does the trick I presume.
That's a harder one ...Philsourish wrote: ↑Mon Sep 13, 2021 12:14 pmIs there a way to remove these "\A1" in a more automatic way ?
E.g. Notepad++
Thank you for your advice,
With Replace Edit: I can find some of the occurrences of "\A1", but the replacement doesn't work on the file itself (both in .dwg and .dxf).
On the other hand it works by editing each block and doing Find Replace "\A1" once and then Find Replace "\A1;"
This is still very tedious
I saved your file as DXF.Philsourish wrote: ↑Mon Sep 13, 2021 3:12 pmWith Replace Edit: I can find some of the occurrences of "\A1", but the replacement doesn't work on the file itself (both in .dwg and .dxf).
Openend the DXF in Notepad++
With Notepad++ replaced all "\A1;" by nothing and then the "\A1"
Saved the file back under Notepad++.
DXF Looks fine when I load it under QCAD.
One can save this back to dwg with QCAD.
Thank you, the result is perfect!
but unfortunately Notepad++ does not work on Linux.
I will look for an equivalent editor to Notepad++ (or use a Windows PC)
Any plain text editor will do ...
[SOLVED]changing the display of room dimensions in blocks
Yes, it works!
many thanks for the help
