I've imported a PNG image file to trace.
However, the file path has changed and the imported file is no longer accessible.
Where can I reset the file path so that the image file is visible?
Better yet, can the image file be embedded into the drawing?
QCAD version: 3.26.4.0
Date: Jun 4 2021
Qt version: 5.8.0
Compiler version: gcc 4.8.1
Build date: Jun 4 2021
Revision: 0bb4334f11f4340e470c4135ae61c076a98f919f
Architecture: x86_64
Device pixel ratio: 1
Configuration file: /home/dave/.config/QCAD/QCAD3.conf
OS: Linux
OS version: 20.10
[solved] Image file paths
Re: Image file paths
Bitmap files are only linked.
One can edit the path of an image entity by its specific property 'File' in the Property Editor.
One can filter on (empty/broken) image entities with the Selection Filter.
Thanks.
Using the Filter I was able to find the image and assign it the new path.
