Hi all,
Like Rob (and thanks Rob and others for the posts), I've also used QCAD for a few years on OS-X (11.6), using QCAD 3.27.6.0 (3.27.6) but struggled to understand how to include a border in a template.
I've managed to create a viewport in the default template, and get my drawing to appear in a scaled version in print preview, but despite reading and re-reading these posts and the QCAD manual, and trying to create the template, I have only managed to make the attached border 'template'. I can't for the life of me get the drawing I'm working on to appear on that template when I create a viewport.
I must be missing something fundamental in the logic of the process so would be grateful for any further guidance!
cheers
Andrew
Print layouts and blocks
Re: Print layouts and blocks
- border template.dxf
- (140.46 KiB) Downloaded 167 times
Hi AndrewMu,
your print template looks already pretty good.
Delete everything in Model_Space and Paper_Space.
Insert the Border etc. Blocks directly and at a 1:1 scale into a Paper_Space. Don't use for that a Viewport!
Your now empty Model_Space is your Worktable. Design your drawing in it in 1:1 - no matter how big or small your project is. If it comes to printing you need to take a Viewport in Model_Space and insert it into a Paper_Space. Your Border etc. is already waiting there for you - just chose a suitable scale for the Viewport and place it within the Border. Print the Paper_Space 1:1 regardless the used scales for the Viewport.
Hope it helps a bit to understand the procedure ....
You may consider to change a few things like ...AndrewMu wrote: ↑Sat Aug 06, 2022 6:01 amI've managed to create a viewport in the default template, and get my drawing to appear in a scaled version in print preview, but despite reading and re-reading these posts and the QCAD manual, and trying to create the template, I have only managed to make the attached border 'template'. I can't for the life of me get the drawing I'm working on to appear on that template when I create a viewport.
Ah .. many thanks Husky - that was indeed very helpful! I think I'm finally getting it .. I'm still refining my understanding, but that's helped me make a big leap forward.
Thanks again
Thanks again
