[solved] Black cursor on Black background
Posted: Fri Feb 18, 2022 1:39 pm
				Hello all,
QCAD Pro, version 3.27.1.0 on Win10
I cannot seem to find a way of making the cursor visible when using certain edit operations.
Draw>Line> 2 Points gives a yellow cross hair as set in the Application Properties. However
Draw>Line>Parallel, Draw>Line>Bisector, Draw>Tangent (Two Circles), Draw>Line>Orthogonal / Tangent and others gives a black cross hair, this is visible if hovering over a white hatched area or block. this action is making it very difficult to select the correct point in the drawing.
I have tried to select different pallets, themes, cursor attributes, but have not found anything that corrects this issue.
please help.
Martin..
please help.
Martin..
