Apple Magic Mouse zoom problem
Marti
Post by Marti » Thu Apr 14, 2022 5:22 pm
Any time I grab my Apple Magic Mouse, it randomly zooms (or scrolls, depending on the prefs) which is very annoying and slows down my work. The mouse seems to be oversensitive to touch. Other mouses are not like that, and other apps either. Is there any way to stop that, other than using a mouse with a wheel? I tried to adjust the zoom speed in QCAD prefs but it didn't help much.
MacBook (Retina, 12-inch, Early 2016)
MacOs Monterey 12.2.1
QCAD Version 3.25.2.11
Re: Apple Magic Mouse zoom problem
Post by andrew » Thu Apr 14, 2022 5:28 pm
Please refer to this topic or search the forum for Magic Mouse:
https://www.qcad.org/rsforum/viewtopic. ... 65&#p32465
What setting did you use for the zoom speed?
ryancousins
Post by ryancousins » Thu Apr 14, 2022 5:52 pm
Marti,
Hopefully changing the zoom factor as mentioned by Andrew will solve your issue. However, in my opinion, the Magic Mouse is absolutely terrible for CAD applications. Even after changing the zoom factor, I found it impossible to zoom in and out with any precision and repeatability. Just my $.02 :D
Marti
Post by Marti » Thu Apr 14, 2022 6:23 pm
Thanks for your advice, changing the zoom factor helps.
I like the Magic Mouse for a couple of reasons: a) scrolling is much smoother than with a wheel mouse, b) I don't have to constantly lift my finger on the wheel to zoom, and c) switching between views/apps with a two finger horizontal swipe is really fast, d) hand/wrist position is more relaxed because the mouse is flatter.
ryancousins
Post by ryancousins » Thu Apr 14, 2022 6:31 pm
I'm glad it is working well for you. I do like the Magic mouse for apps for those reasons.
