.PDF export and scale
timelrd
Post by timelrd » Fri Apr 22, 2022 2:47 pm
I have been trying to export to .PDF but when I do nothing is visible. I load the saved .PDF and it is blank. One other issue I ran in to when it was recommended on this forum for printing that you have to set your scale as I thought maybe that was why the .PDF was blank. Scale isn't accessible or active to click. Please help.
Using windows 11, QCad version 3.27.1.0
GRINDER.pdf
(12.74 KiB) Downloaded 155 times
Re: .PDF export and scale
Post by andrew » Fri Apr 22, 2022 3:02 pm
Please attach your drawing file (DXF, DWG), thanks.
timelrd
Post by timelrd » Fri Apr 22, 2022 3:44 pm
I have made some changes, here is the updated file.
GRINDER.dxf
(113.1 KiB) Downloaded 174 times
Post by andrew » Fri Apr 22, 2022 3:47 pm
The drawing is beside the page. You fit on the drawing on the paper. Please refer to:
https://www.qcad.org/en/tutorial-printing
Screenshot 2022-04-22 at 16.47.30.png (106.49 KiB) Viewed 1607 times
