Pocketing
RobB
Pocketing
Post by RobB » Tue May 03, 2022 3:53 pm
Attached file has a rectangular object with an internal island. Both are polylines. Most of the times, the polyline offset command does not see the internal polyline and writes the whole block full of parallel lines. I have tried to change the polyline direction, regenerate them etc, but if it properly generate the pocketing area is a hit or miss. What is required for both polylines to keep the inner line as boundary?
Thanks, Rob
Version:
3.27.3.0 (3.27.3)
Internet:
QCAD.org
Build Date:
Apr 28 2022
Revision:
a6c73c5
Qt Version:
5.14.2
Architecture:
x86_64
Compiler:
gcc 5.4.0
150-02 Stepper connector plate for mini ITX box.dxf
(147.22 KiB) Downloaded 287 times
Linux Mint 20 , qcadcam-3.24.3.10-pro-linux-x86_64
Re: Pocketing
Post by Husky » Tue May 03, 2022 6:53 pm
Hi Rob,
The Polyline Offset tool is not able to detect the inner polyline by design.
I recommend to use a single offset plus an exploded hatch to pocket that area. Depending on your needs it could look like this ....
BTW: Lunch in this drawing also the "Detect Zero Length Entities" tool to get rid of the "imperfection" ... :lol:
Re: Pocketing
Post by andrew » Tue May 03, 2022 8:09 pm
To make sure the offset tool recognizes islands, you need to select all the contours and then use the offset tool:
Screenshot 2022-05-03 at 21.08.09.png (49.47 KiB) Viewed 2416 times
See also user manual at:
https://qcad.org/doc/qcad/latest/refere ... /OffsetPro
Re: Pocketing
Post by Husky » Tue May 03, 2022 8:21 pm
Ouch .......... my bad! :lol: :lol: :wink:
Re: Pocketing
Post by andrew » Tue May 03, 2022 8:27 pm
It's easy to miss as it's an unusual use of selections. But it's the only convenient way to "choose" multiple entities for an operation.
RobB
Re: Pocketing
Post by RobB » Tue May 03, 2022 9:10 pm
Thanks,
I got the method from this forum topic:
https://www.qcad.org/rsforum/viewtopic. ... php?t=5411
In trying, I selected probably everything a few times, hence that is why it sometimes worked.
Will try again.
Thanks Andrew.
Edit: Just tried again, and now I see that there are two icons for Offset: Polyline Offset (alternative) in 'Misc Draw' which I used all times, and Polyline Offset in 'Polyline', which worked as desired. No idea what the difference is.
