Solved thanks-Lock Snap - SQ
amsmarle
Post by amsmarle » Thu May 12, 2022 6:03 pm
Hello, I have Qcad Pro - windows 10
Please can you explain how and when and how I might find Lock Snap to be most helpful
I use the line tool - 'line from 2 points' and find when the drawing becomes larger, snapping to intersections, middle or end sometimes the drawn line
is not at right angles (straight)
Thanks for any advice
Alan
Re: Lock Snap - SQ
Post by Husky » Thu May 12, 2022 7:50 pm
QCAD will reset a chosen snap when switching to an other tool. If you like to avoid that you can lock the chosen snap.
Right angle to what? Could it be that you meant horizontal / vertical? To have a perfect horizontal or vertical line you can use the restrictions (EH, EV) or alternative the ALT key on your keyboard. How? Line / first point / press and hold ALT key / second point.
amsmarle
Re: Solved (thanks) Lock Snap - SQ
Post by amsmarle » Fri May 13, 2022 5:03 pm
Solved
