dwg2bmp with 1 unit = pixel
Post by andrew » Thu May 26, 2022 4:25 pm
From a QCAD user:
How can I convert a DXF/DWG to a bitmap (PNG, TIFF, etc.) with one drawing unit being exported as exactly one pixel?
Re: dwg2bmp with 1 unit = pixel
Post by andrew » Thu May 26, 2022 4:28 pm
Use -r 1 (resolution of 1) to export a drawing unit to one pixel.
Use -m 0 to remove any margins.
Use -no-weight-margin to avoid adding additional margins to compensate for line weight.
Optional: use -a for antialiasing (to make sure lines along the borders are still visible)
To summarize, you can use a command like this:
dwg2bmp -f -r 1 -m 0 -a -no-weight-margin -o output.png input.dxf
