Adding unit to dimension label
Post by andrew » Thu Jun 02, 2022 8:42 am
From a QCAD user:
How can I add the unit of measurement to a dimension label?
Re: Adding unit to dimension label
Post by andrew » Thu Jun 02, 2022 8:49 am
Typically, one would indicate the drawing unit in a drawing header (for example: "All units in Inches unless stated otherwise").
To add a unit (or any other text) to a dimension label, you can use <> in the dimension label text for the actual measurement.
For example:
Results in 30" if the measurement is 30".
R<>mm
Results in R12mm if the measurement is 12 drawing units, etc.
You can edit the dimension label text while creating a dimension in the options toolbar:
Screenshot 2022-06-02 at 09.47.21.png (58.98 KiB) Viewed 1051 times
Or you can change it later for all selected dimensions in one go using the property editor:
Screenshot 2022-06-02 at 09.47.36.png (68.8 KiB) Viewed 1051 times
