[Solved] Patterns/Hatch folder
Claus N
Post by Claus N » Tue Jun 14, 2022 2:09 pm
Sorry, I has been a while, so I have forgot where the folder for adding hatch pat-files is located. In vain I have spent time looking for it and thus would appreciate some assistance if possible :)
best
Claus
Claus Nybroe
QCAD 3.29.40 - Win10
Re: Patterns/Hatch folder
Post by Husky » Tue Jun 14, 2022 6:09 pm
C:\Users\User\AppData\Roaming\QCAD\Patterns\imperial
C:\Users\User\AppData\Roaming\QCAD\Patterns\Metric
Claus N
Post by Claus N » Tue Jun 14, 2022 8:28 pm
Thumps up !! :D
Claus Nybroe
Re: [Solved] Patterns/Hatch folder
Post by CVH » Wed Jun 15, 2022 5:39 am
Following the changelog info for 3.26.2 (2021/04/15):
  • •Add local data location to search path for resources files (patterns, linetypes, fonts, postprocessors, etc.)
    ◦Windows: C:/Users/[Username]/AppData/Local/QCAD/QCAD
    ◦macOS: ~/Library/Application Support/QCAD/QCAD
    ◦Linux: ~/.local/share/QCAD/QCAD
Using the same sub-folder structure as the main application that works as such over here.
There I have custom patterns, scripts and so on installed.
