Mixed format of dimensions
rluke
Post by rluke » Sun Jul 24, 2022 5:24 pm
Is there a way to have some dimensions displayed as feet and inches while others are displayed as inches only?
Example: The outer dimensions of a building in feet and inches while the interior details displayed as inches only?
Rich
Qcad Pro
Windows 10
Re: Mixed format of dimensions
Post by Husky » Sun Jul 24, 2022 7:09 pm
Drawing Preferences:
Drawing Unit = Inch
Dimension Settings / Label Format = Architectural or Engineering.
"Only inches" are used if the measurement is less than a foot.
Note: The Property Editor can also be used to modify every single or a bunch of dims to suit your needs.
rluke
Post by rluke » Sun Jul 24, 2022 7:55 pm
Thanks you Husky
