Tolerance for diameter
K0nrad
Post by K0nrad » Thu Jul 28, 2022 7:26 pm
Is there any possibility in QCAD to add (automatically) the tolerance for the circle diameter?
I know it is possible for the straight lines. I would like it to look like in the attached drawing.
Regards
Konrad
QCADCAM 3.27.6
Re: Tolerance of diameter
Post by andrew » Thu Jul 28, 2022 7:28 pm
Tolerances for diameters work the same way as for linear dimensions. You can set them during construction in the options toolbar at the top or later in the property editor.
K0nrad
Re: Tolerance for diameter
Post by K0nrad » Thu Jul 28, 2022 8:44 pm
Thank you! I see it now :-)
