Dimension
SteveO
Dimension
Post by SteveO » Mon Aug 01, 2022 4:44 pm
When I use the dimension tool, I would like to add dimensions without the dimension lines. Is there a way to do this? Thanks
Re: Dimension
Post by Husky » Mon Aug 01, 2022 6:39 pm
Yes but I wouldn't recommended that: Explode the dim and delete the dimension lines.
petevick
Re: Dimension
Post by petevick » Tue Aug 02, 2022 6:58 am
wouldn't that just be text ??
Pete Vickerstaff
Linux Mint 21.2 Cinnamon, Qcad Pro 3.29.4
Re: Dimension
Post by CVH » Tue Aug 02, 2022 8:18 am
Yes indeed, I think that the question should be which of the dimension lines should be omitted. :wink:
https://qcad.org/rsforum/viewtopic.php?t=9394
Re: Dimension
Post by Husky » Tue Aug 02, 2022 9:31 am
Nope. The last time I checked a dimension consists out of a Dimension Line, Extension Lines, Text and arrows or ticks.
petevick
Re: Dimension
Post by petevick » Tue Aug 02, 2022 10:07 am
ok, so take away the dimension lines and you're left with text, extension lines and arrows/ticks, the extension lines and arrows/ticks are pretty useless in my opinion without dimension lines, so delete those and you're left with text. This is all my opinion obviously.
Pete Vickerstaff
