Adding text to measurements by default
wendi
Post by wendi » Wed Aug 03, 2022 5:23 am
Win10Pro64, Qcad 3.27.6. I know that if I set a measurement label to <>", I will get the numerical dimension automatically, with " after the number. But I've been doing it manually for all of my dimensions. Is there are way to have Qcad default to that?
Re: Adding text to measurements by default
Post by CVH » Wed Aug 03, 2022 5:56 am
wendi,
I think not.
One could enter a feature request for a user defined suffix similar as the dimension prefix.
But that is also one of the few QCAD options that isn't stored persistent.
Although 'Prefix' and 'Text' are reserved keys in the QCAD.ini/config under the header [Dimension].
They don't seem to be updated ...
One could filter out all dims with the Selection Filter and adapt all in one go. :wink:
Post by Husky » Wed Aug 03, 2022 6:42 am
Hi wendi,
You may set the dimension label settings to Architectural. Drawing Unit needs then to be Inch. Will that work for you?
wendi
Post by wendi » Thu Aug 04, 2022 3:05 am
Hi CVH. Thanks for the info. I do update them in groups, from time to time.
Hi Husky. Inches won't work for me. Thanks for the idea.
Wendi
Post by Husky » Thu Aug 04, 2022 5:16 am
Sorry that I misunderstood your question. I was sure you were asking expliziet for inches after the number ...
