[solved] Filter Only Within Selected Objects
seasdes
Senior Member
Post by seasdes » Mon Sep 12, 2022 1:41 am
Sometimes I need to run a filter within selected objects only. Is there a way to do this?
Currently when I run a filter command it operates on all of the entities displayed.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Filter Only Within Selected Objects
Post by CVH » Mon Sep 12, 2022 4:01 am
The Selection Filter has 4 methods represented by icons:
- Replace Current
- Add
- Subtract
- Intersect
To filter within an existing selection one can use the Intersect method.
To filter out unwanted one uses the Subtract method.
Post by Husky » Mon Sep 12, 2022 4:25 am
No, unfortunately there is no way to do that. I would appreciate that option too ... :(
Post by CVH » Mon Sep 12, 2022 5:17 am
Also see:
https://qcad.org/doc/qcad/latest/refere ... tionFilter
... Usage ... 6 ... last line
seasdes
Senior Member
Post by seasdes » Mon Sep 12, 2022 5:19 am
- Replace Current
- Add
- Subtract
- Intersect
Hmm I have to get my head around that suggestion
seasdes
QCAD Pro V3.27.8
User since 2021
W10
seasdes
Senior Member
Post by seasdes » Mon Sep 12, 2022 5:35 am
Also see:
Aha. Thank you CVH.
The highlighted line in the manual allows me to do what I want.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Post by CVH » Mon Sep 12, 2022 5:43 am
Aha. Thank you CVH.
Glad to help you out.
It only took me a while to retrieve the correct link to the manual ... :wink:
seasdes
Senior Member
Post by seasdes » Mon Sep 12, 2022 5:46 am
Aha. Thank you CVH.
Yeah I looked. Couldn't see the forest for the trees.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Post by Husky » Mon Sep 12, 2022 6:21 am
Yep, me too. Thanks CVH for pointing that out.
