[solved] cannot edit dxf file
silogy
Post by silogy » Sat Sep 24, 2022 2:45 am
I am unable to edit the attached dxf file; all the line segments (268) are selected when any one is selected. The file was generated from a sketch in Fusion 360, using a method that I have used at least a dozen times and successfully edited in QCAD. Is there a property that I need to set to successfully edit this file?
I work on a 2018 iMac running Mac OS 12.6 on an Intel Core I5 with 8 GB of memory and 1 TB of storage. I am running QCAD Pro version 3.27.6.
keelProjection.dxf
(13.42 KiB) Downloaded 164 times
Re: cannot edit dxf file
Post by Husky » Sat Sep 24, 2022 4:30 am
that is a polyline built out of 268 lines.
To have it as single lines select the polyline and explode it. You can find that tool below Menu/Modify) - that's all what it needs ... :wink:
silogy
Post by silogy » Sat Sep 24, 2022 3:26 pm
Thank you, exploding the poly line worked! I just do not understand how the exported file from Fusion 360 became a poly line.
