Sorry if this is a dup. I tried to look this up on this forum and couldn't find it.
1) How do I see the size of an rectangle that already been drawn, e.g. 5 x 3
2) Let's say I want to move the right side in by 0.5 whatever-unit but leave the rest untouch... How do I do that? The scale tool resize it form the center.
3) How do I change the location of one of the nodes by x amount? I tried to click on it and type in something on the lines of move @0,-1 but it did nothing.
4) How do I select 2 nodes at once to move them?
Sorry for this noob question but I couldn't figure it out as it is not intuitive in Qcad for some reason. I downloaded the free version of nanoCad which is the outdated version and it was straight forwards in that program for all of these things.
Thanks for reading
- Math
Resizing a side of an rectangle
Re: Resizing a side of an rectangle
Math,
From the picture I presume that the rectangle is a hatch entity.
One can relocate the corner markers by left-click and hold on them and drag them to a new location.
Or once they stick to your mouse cursor you can type in a new position in absolute/relative and/or polar coordinates in the Command Line.
Hatches are usually added in a final stage.
A bounding rectangle as a polyline has more reference marks/options to reshape.
Please read the forum rules: Post one question per topic.
It all depends on where you set that before you perform the scale.
No, the scale tool (SZ) works with a focus point.
You can't select 2 or more reference markers at once unless they are at the same position.
Math,
BTW ... I don't see the Status Bar on your screen grab.
You can activate/deactivate that by typing GS or by the View menu.
On the Status Bar is a mouse icon with current tool instructions.
Okay but how do I get the dimensions of a rectangle?
Edit Ah I can not do it with a hatch.. Is there a way to auto update a hatch if I resize the polyline than or would I have to delete it and remake it? If not would the best way to put them on separate layers?
If the rectangle is a polyline - select the shape and check for the dimension the Property Editor.
If the rectangle is built out of lines - select the line to get the dimension also within the Property Editor.
Autoupdate - nope.
Delete and remake - that is one possibility. It depends on the shape which "dictate" the best approach to tackle that task. In many cases the Stretchtool is the best way to go ...
Hatch on separate layer - yes, that would be common praxis and is recommended.
