Problem with text render opening dwg file
atossa
Post by atossa » Tue May 18, 2021 8:33 pm
I'm using Qcad 3.26.2 on PopOS 20,10.
I attached a screenshot of my screen on Qcad (black background) and one of my colleage on Drafsight (white background) of the same dwg file.
Text is not rendering well on Qcad. Pay attention to the word "electrique" of the "Armoire d'alimentation electrique".
It is too big and seems completly detached (at a wrong place).
It's the same for the word "entreprise" on the left side of the picture.
And so on on all dwg files I open with Qcad.
What settings should I change to get good rendering?
Re: Problem with text render opening dwg file
Post by Husky » Tue May 18, 2021 9:46 pm
please attach the dwg to your post or an example dwg which shows the same issue for further investigation. Thanks.
