[Solved] setting line lenght in the lh or lv command
RobB
Post by RobB » Sat Jul 24, 2021 4:01 pm
Entering lh or lv: it displays the tool box for the line length, but I cannot enter a value.
the lineangle command works OK.
Rob
QCAD/CAM
Version:
3.26.4.0 (3.26.4)
Internet:
QCAD.org
Build Date:
Jun 4 2021
Revision:
0bb4334
Qt Version:
5.14.2
Architecture:
x86_64
Compiler:
gcc 5.4.0
Linux Mint 20 , qcadcam-3.24.3.10-pro-linux-x86_64
Re: setting line lenght in the lh or lv command
Post by andrew » Sat Jul 24, 2021 4:52 pm
You are likely drawing infinite lines or rays which by definition have an infinite length:
https://qcad.org/doc/qcad/latest/refere ... e/doc/Line
RobB
Post by RobB » Sun Jul 25, 2021 8:25 am
Andrew thanks, that was the problem.
I used infinite line before and it remembered that.
Rob
