DWG Import Fail
DWG Import Fail
Hi Im trying to open a document saved by micro survey I can open it in every program I have access to that can handle a dwg/dxf except for Qcad(pro version 3.27.6.0) I've tried to open it in Autodesk 2018/2013dwg as well as ASCII/binary DXF I get the same result each time a popup that says "Cannot open file "S:\Projects\2269 Ramm Johsten Rd\PRE CALC\2269_resave.dwg" "Import failed." It seems to Be a Qcad specific issue. I've already uninstalled and re installed the program. any help/guidance is appreciated.
- Qcad import fail.png (137.73 KiB) Viewed 4993 times
- 2269_resave.dxf
- (308.66 KiB) Downloaded 207 times
- 2269_resave.dwg
- (49.37 KiB) Downloaded 200 times
- 2269_NewCalc_20220909.dwg
- (51.47 KiB) Downloaded 194 times
Re: DWG Import Fail
those drawing contain 3D (Z) information. QCAD is a 2D program. You can flatten the drawings with Menu/Misc/Modify/Flatten drawing to 2D.
Re: DWG Import Fail
I cannot reproduce the problem with opening the file here. What exact platform are you on (Windows version, 32bit, 64bit)?
Can you try to copy the file to your Desktop? There could be a permission problem or it could be locked.
Re: DWG Import Fail
So after a little experimentation. It would appear that the issue is with my OS,(win 10 pro x64) my specific installation of Qcad, or my hardware. I got 2 co-workers to open it on there machines(win11 pro and Linux Mint) and it opens just fine, but I cant open drawings from them. I'm really at a loss as to wear to go from here, I've been looking for issues with my PC but I don't even know what to look for, and every other program on my PC runs as expected. Does anyone know what causes this specific message to appear? maybe that will help me narrow down the issue.
Re: DWG Import Fail
Its not just 3D documents I cant open, I cant open ones that have been flattened either, regardless. I have yet to run into an issue with 3d line information, Qcad is not a 2D only modeling program. I cant open the document in the first place so using the flatten command is impossible
Re: DWG Import Fail
Like Andrew I have no problems to open those example drawings regardless the 3D information. I'm on a Win10 OS. Did you try Andrews suggestion?
Your screenshot shows a paths to S:. Is that directly on your computer or on an extern drive?
Re: DWG Import Fail
Husky wrote: ↑Tue Oct 18, 2022 11:59 pmLike Andrew I have no problems to open those example drawings regardless the 3D information. I'm on a Win10 OS. Did you try Andrews suggestion?the S:. location is the an HDD mounted to Bus 3, but I get the same results if I try to open the documents from either of my native SSD's or any of my other disks or removable drives. I haven't tried opening from a remote drive but I doubt that would be fruitful. I tried opening it from desktop but I got the same result i checked the permissions and everything seem right, so I don't think its that
Re: DWG Import Fail
Ok, thanks for clarification. Which Qcad packet (Installation packet) is used for the installation? Please tell me the entire file name.
Re: DWG Import Fail
I installed with a package from a coworker, it was zipped in W.I.N.E. and I had to use a 3rd party utility to unpack it. The file name is qcad-3.27.6-pro-win64. I can send you a drive link to the unzipped files if that will help. were should I get a fresh install pack from?
Re: DWG Import Fail
That usually happens if you open a drawing in AutoCAD and then try to open the same drawing in QCAD. Even if you open a different drawing afterwards in QCAD it aint gonna work(Import fails). You have to close the drawing in AutoCAD(it's not necessary to close AutoCAD itself). Close QCAD and then open QCAD again. Now it's possible to open the drawing in QCAD.
Re: DWG Import Fail
What would mean that ACAD locks the drawing.
Very odd because I don't think that other drawings will be locked too.
What would mean that ACAD locks the source path and/or that QCAD locks up.
A single QCAD licence is personally, one should not distribute personal copies.
A fresh install pack can be sourced from the general download area:
https://www.ribbonsoft.com/en/download
For QCAD PRO you need to buy a licence and then you can download an installation package from your personal download area:
https://www.ribbonsoft.com/en/online-shop
One can also buy a site license so that you and up to 20 coworkers on one site can use QCAD.
