How to crop a specified region from DWG/DXF and convert it to BMP via command line?
dreamskyer
Post by dreamskyer » Tue Jun 10, 2025 12:32 pm
Problem:How to crop a specified region from DWG/DXF and convert it to BMP via command line?
Current command:
./dwg2bmp -platform offscreen -zoom-all -width=6000 -height=6000 -window 2000000,-573237.78,3552109.93,643795.06 -flat -f B.dwg
Issue:
Cropping by coordinates to BMP does not work.
Environment
Linux Centos7
Qcad 3.23.3
Expected output:
Expected output.png (25.33 KiB) Viewed 28142 times
B.dwg
(6.3 MiB) Downloaded 302 times
Re: How to crop a specified region from DWG/DXF and convert it to BMP via command line?
Post by andrew » Tue Jun 10, 2025 12:48 pm
Try:
./dwg2bmp -platform offscreen -zoom-all -width=6000 -height=6000 -window=2000000,-573237.78,3552109.93,643795.06 -flat -f B.dwg
Note the = after -window.
Note that your window has a different format than your bitmap size. QCAD will center your window on the bitmap format.
