Mac Book Pro Sonoma 14.1.1 Using Logitech Mouse with Logi Option+ Driver and QCAD 3.28.2
Cannot use the zoom wheel to zoom in and out because just touching the zoom wheel starts the zoom in or out to the maximum. Even if settings on Logitech are set to a minimum where the mouse wheel just clicks once, QCAD reacts if you are doing a continuous zoom.
Thanks.
Using Middle Scroll wheel on mouse to zoom
Mac: Big Sur version 11.4
QCAD Pro
QCAD Pro
Re: Using Middle Scroll wheel on mouse to zoom
You can adjust the mouse wheel sensitivity under:
Edit > Application Preferences > Graphics View > Navigation > Mouse wheel zoom factor
Try e.g. 1.02 instead of 1.2
