The issues with the command line tool dwg2pdf
hik-IT
Post by hik-IT » Tue Jul 15, 2025 10:00 am
I have a DWG file that I converted to PDF using the command line tool dwg2pdf.
The command used was: ./dwg2pdf -platform offscreen -auto-fit -auto-orientation -center -max-lineweight=0.005 -flat -f -o 1.pdf A.dwg
the issues is :After conversion, I found significant differences between the PDF and original DWG content - many unexpected color blocks appeared in the PDF. How can I adjust settings to achieve a PDF output that matches the DWG file exactly?
Environment
CentOs7
Qcad 3.23.3 pro
Qcad 3.23.3 server
1.pdf
(15.98 MiB) Downloaded 639 times
A.dwg
(7.66 MiB) Downloaded 135 times
Re: The issues with the command line tool dwg2pdf
Post by CVH » Tue Jul 15, 2025 11:50 am
Probably the same file as in topic 11703
Again QCAD failed to open that at my side, probably because of the same errors: See error.log in related topic.
I can see those in the PDF but I am limited to scale that up to 6400%.
Suspecting heavy weights and/or global polyline widths.
Remind that a Lineweight like 1.00mm is never scaled and remains exactly 1mm wide on paper disregarding how small the detail becomes.
Perhaps exporting to a larger page size than A4 is a solution. :wink:
