PDF Export and Printing are slightly off scale
Posted: Fri Jan 09, 2015 6:17 am
I have a mockup of an airplane instrument panel that I'm trying to print to exact size on paper.
I printed it at home onto multiple 8.5x11" sheets and it appeared to be off scale a little when assembled.
So I took the exported .pdf to a FedEx/Kinkos and had them print it actual size to a large format printer.
The approx. size of the panel is 16" x 40". What I found was that the printed image was slightly smaller
than the actual parts. I verified by dimensioning within qcad that the parts were created to the proper size, but the pdf just comes out too small. It's even noticeable if you measure on the PC monitor.
It appears that to print correctly, I'd have to scale very slightly, like print 1:1.0042
I have also tried rather than just using the built-in pdf export, printing to a pdf print driver set to a 24" x 48" sheet of paper. That comes out with the same results.
Within the pdf print driver, I do have the ability to scale to adjust a little, but only in full percentages (i.e. 101%) which is not fine enough to be able to get almost perfect.
The print shop CAN print DWF files or PDF files. But I don't think that Qcad pro can export .dwf format.
Can anyone give any tips that may get this thing to print to perfect scale?
Thanks for any help!
