(solved) Screen all black
Navajo
Post by Navajo » Mon May 18, 2015 9:25 pm
Hi
I´m on 3.9.3 on a OSX Yosemite. Whenever I open a drawing the drawing area is all black. Can´t see my drawing at all. Only solution is to use select all ->copy -> paste to new drawing. Only then am I able to see the drawing again. This will happen again if I save the new drawing.
Any ideas anyone?
Best regards
Johan
Navajo
Re: Screen all black
Post by Navajo » Mon May 18, 2015 10:11 pm
Looks like this Image
/Johan
Post by andrew » Tue May 19, 2015 8:04 am
Looks like there is a huge entity in the drawing file. If you attach the drawing file (DXF/DWG), I can probably help.
Navajo
Post by Navajo » Wed May 20, 2015 9:36 am
Here is the file.
/Johan
Pipes.dxf
(163.37 KiB) Downloaded 365 times
Post by andrew » Wed May 20, 2015 9:52 am
There were two huge circles in the file. Here's the fixed file.
Pipes_w.dxf
(163.33 KiB) Downloaded 367 times
Navajo
Post by Navajo » Thu May 21, 2015 7:48 am
Thank you for your kind help.
Best regards
Johan
