(solved) copy and paste scaling the entities
mitch37
Post by mitch37 » Wed May 27, 2015 9:24 am
S.O. ubuntu 14.04
qcad 3.9.4
when I use copy and paste from icon or shortcuts (ctrl+c and ctrl+v) in the same drowing or between two drawing the entities paste scaled of 0.03. I use qcad in two computer (work and home) with the same S.O. and only one have this problem.
mitch37
Re: copy and paste scaling the entities
Post by andrew » Wed May 27, 2015 9:38 am
Please check the options tool bar when pasting. It allows you to scale, rotate, mirror entities while pasting:
Screen Shot 2015-05-27 at 10.38.48.png (27.33 KiB) Viewed 3745 times
Make sure that the scale factor is 1 or reset all options to default (1:1, no rotation, no mirroring) by clicking the reset button at the right.
Note: when copying / pasting between different drawings, the drawing unit is taken into account. I.e. copying a 10 unit long line from a drawing in Millimeters to a drawing in Centimeters results in a 1 unit long line.
mitch37
Post by mitch37 » Wed May 27, 2015 11:21 am
ok, i don't see the scale factor of the paste. I solved
thanks
mitch37
