I challenged a couple problems to find the "Intersection" snaps on Splines. The snap tool will ignore a couple of intersection or even jump to the end of the spline. If I explode the spline to a polyline everything works as expected.
I'm doing something wrong?
I noticed this after working with a locked intersection snap.
Testdrawing with Line / Polyline / Spline intersections ...
Can't find the correct intersection on splines ...
Re: Can't find the correct intersection on splines ...
Thanks. This seems to be related with the lines being vertical and has been fixed for the next release.
Thank you.
