Font "Liberation Sans"
Post by Husky » Sat Jun 18, 2016 9:21 am
I used the new template din6771-1_de_portrait_a4.dxf and now I'm wondering about a text font in this template. Used and displayed is a font named "Liberation Sans" but I'm pretty sure I don't have this font normally on my system and I can't find it in the QCAD Font folder nor the QCAD Font controls.
Where is this font coming from?
riverbuoy
Senior Member
Re: Font "Liberation Sans"
Post by riverbuoy » Sat Jun 18, 2016 4:48 pm
Hi Husky,
The font 'Liberation Sans' is a free font that comes with most (if not all) distributions of the Linux operating system. This particular font is a replacement for 'Arial'. If you google this you can find all the information you want (and more).
As it is free, you could download and install it for free on your computer. However, as it replaces the Arial font, you could just change the template to use Arial.
Hope this helps
riverbuoy
Post by Husky » Sat Jun 18, 2016 7:59 pm
Hi riverbuoy - thanks for explanation regarding the Linux OS fonts. Sorry - my fault - I forgot to mention that I run on Windows .... :oops:
hungerburg
Senior Member
Post by hungerburg » Fri Jun 24, 2016 11:42 am
I guess you get the font when you install open/libre-office on your system.
Post by andrew » Fri Jun 24, 2016 12:20 pm
The use of "Liberation Sans" is actually more of oversight. This will be changed to "Arial" in the next release which is far more likely to be available on all systems.
