[solved] Lost ability to minimize/exit screen
dfulper
Post by dfulper » Sun Jun 19, 2016 8:55 pm
I have been using following QCADCAM on a windows 10 x 64 system for a couple of months and today lost the icons in upper right portion of screen that allow me to minimize and exit the program.
Version: 3.14.3.0 (3.14.3)
Build Date: Apr 26 2016
Revision: c4f0833
Qt Version: 5.5.1
Architecture: x86_64
Compiler: MSVC++ 12.0 (2013)
I unistalled program and noticed the shortcuts still would launch program, so entered "QCAD" in launch bar and deleted all shortcuts, and then deleted all program folders. After reinstall, I notice the program still can list my most recent files, so there is still some configuration data somewhere that I am not seeing.
I can minimize the screen by ALT+Spacebar, but would prefer to get my icons back.
Thanks,
df
Re: Lost ability to minimize/exit screen
Post by Husky » Sun Jun 19, 2016 11:01 pm
sounds like the "Full Screen" mode (Menu/Window/Full Screen) is activated. Try to toggle that mode with the function key "F11" on your Keyboard.
dfulper wrote:... I notice the program still can list my most recent files, so there is still some configuration data somewhere that I am not seeing.
All QCAD settings are stored in the QCAD3.ini which is also responsible to store and recall your most recent files and ... the "Full Screen" setting. :wink:
I'm not absolutely sure about the Path in Win 10 but it should be found below somewhat like: C:\Users\username\AppData\Roaming\QCAD\QCAD3.ini
dfulper
Post by dfulper » Tue Jun 21, 2016 1:47 am
Many thanks. F11 did the trick.
Thanks,
df
