print/pdf fails
davidjmcq
print/pdf fails
Post by davidjmcq » Mon Sep 05, 2016 2:36 pm
Version: 3.15.5.0 (3.15.5)
Ubuntu 12.04
I'm completely new to CAD, so forgive me if the answer is obvious.
I've imported a drawing created by a surveyor - no idea what program he used. I've then added my own bits to it. Now I need to print it - pdf or jpg or ps, anything will do.
Mostly I get a blank page. I created an enormous jpg which gave me a tiny image in the corner of the page. That makes me think that I may have a scale problem, but I find the scaling confusing. I've tried all of the suggestions I've found in forums with no luck.
I've attached the dwg file.
The problem is becoming urgent as someone is waiting for this drawing, so any help is appreciated.
pool-v3.dwg
(204.16 KiB) Downloaded 327 times
Re: print/pdf fails
Post by andrew » Mon Sep 05, 2016 2:39 pm
Please work through our detailed printing tutorial first at:
http://www.qcad.org/rsforum/viewtopic.php?f=47&t=3317
If you cannot fix the issue, please post back, thanks.
Re: print/pdf fails
Post by Husky » Mon Sep 05, 2016 4:11 pm
Hi davidjmcq,
davidjmcq wrote:... The problem is becoming urgent as someone is waiting for this drawing, so any help is appreciated.
I checked your drawing and found a few "lost" text entities in the far upper right corner:
Delete or rearrange them and then try a printing scale around 1:400 - that should work.
Re: print/pdf fails
Post by Husky » Mon Sep 05, 2016 6:13 pm
davidjmcq wrote:That makes me think that I may have a scale problem, but I find the scaling confusing. I've tried all of the suggestions I've found in forums with no luck.
Yep - me too :wink:
I think you also found a bug and I've already filled a bugreport.
http://www.ribbonsoft.com/bugtracker/in ... sk_id=1475
We will see ... 8)
davidjmcq
Re: print/pdf fails
Post by davidjmcq » Tue Sep 06, 2016 8:11 am
Thanks for replies. This is what happened to me for the sake of anyone else stumbling on this post.
First, I had some orphan elements that were increasing the size of the printing area dramatically. Once I deleted those things started to improve. Thanks to Husky for spotting that. I found them by reducing the size of the image on screen (mouse wheel) until it was practically invisible, then "Select All", then the selected orphans showed up clearly as blue splodges.
I failed to understand what "scale" meant (because I'm new to CAD?) I was printing on A4 and the plan is about 63 metres by about 25 metres. By setting a scale of 1:300 in Edit/Drawing Preferences/Printing/Page it started to make more sense.
I found that the A4 page printing area was set with absolute zero on the bottom left corner. My drawing had zero at the top right. I have no idea how or why that happened. Does the print area always have absolute zero there? In "Print Preview" I simply moved the entire image (select all, move/copy) into the white page image area and now I can print/pdf.
Re: print/pdf fails
Post by Husky » Tue Sep 06, 2016 6:51 pm
Thanks for the update!
davidjmcq wrote:Does the print area always have absolute zero there?
No, the print area doesn't needs to be to absolute zero - QCad is able to handle all other position.
davidjmcq wrote:In "Print Preview" I simply moved the entire image (select all, move/copy) into the white page image area and now I can print/pdf.
QCad has extremely powerful tools to handle a situation like that one: Please check next time the Option bar after you launched the Print preview - you will find tools for "Move Paper position" / "Auto fit drawing to page" / "Auto fit pages to drawing" / "Auto center".
No need to change the drawing or to reposition a drawing just for printing. :wink:
