[solved] Text not saved
Hello, for some reason QCAD has stopped saving text.
The command line says, "Exception occurred. Entity not saved: ###"
This pretty much makes QCAD unusable. I have tried saving multiple formats, restarting, and reinstalling. I am using Windows 7 Professional.
Thank you,
Galen
Thank you,
Galen
Re: Text not saved
Hello Galen - welcome to the forum!
Please indicate your QCAD Version and post this troublemaking drawing or at least an example drawing which shows the same behavior. Thanks
Re: Text not saved
Thank you for your prompt response.
Version: 3.15.5.0 (3.15.5)
Build Date: Aug 19 2016
Revision: 15ef1a1
QT Version: 5.5.1
Architecture: x86_64
Compiler: MSVC++ 12.0 (2013)
This occurs with literally any and every file with text. I should mention that this started shortly after I pasted this angle symbol ∠ into a textbox of a different .dwg file.
Revision: 15ef1a1
QT Version: 5.5.1
Re: Text not saved
No problems here to save/reopen a drawing with this symbol. I run on a windows OS.Galen wrote:This occurs with literally any and every file with text. I should mention that this started shortly after I pasted this angle symbol ∠ into a textbox of a different .dwg file.
Re: Text not saved
Here is an example
- Test.png (127.41 KiB) Viewed 5373 times
- test.dwg
- (15.99 KiB) Downloaded 252 times
Re: Text not saved
Sorry - I can't reproduce that on my machine.
Question: Your QCAD Version is a Pro, correct?
And ... what kind of redirected path is that to save that file on your Desktop? That looks not like a standard Win7 path. Have you tried to save this troublemaking drawing to a standard path like "C:\Users\xxx\Desktop" and maybe much more important without Special character like this $ symbol.
Re: Text not saved
I am using the pro version.
Saving to the C drive has the same problem.
Another note I just uninstalled and re-installed QCAD using Revo uninstaller which removes the registry entrees as well, but when I went to add text the text box was already filled with the last text I had typed. This means that QCAD is saving data somewhere that is not being removed with a full uninstall. Could you tell me where else QCAD stores data so that I can remove all of the program?
- Untitled.png (198.57 KiB) Viewed 5367 times
Re: Text not saved
UPDATE:
I was able to get rid of the problem by loading an old .dwg file. I presume there was an invisible character saved to the QCAD clipboard that the system did not recognize. If that is true this is completely my fault. On the flip side it would be nice if the clipboard was cleared on restart. It would also be nice to have a search bar for special characters.
Thank you for your help. I hope this is your largest problem today.
Re: Text not saved
Hi Galen,Galen wrote:I am using the pro version.
QCAD will use the qcad3.ini to store the settings like your last text etc.. This qcad3.ini isn't stored in the qcad directory - you will find the location regarding this troubleshooting page: http://www.qcad.org/en/qcad-documentati ... leshooting
If you delete this file all your setting for QCAD are gone. Maybe it would be a good idea to rename this file first as a backup instead to delete it finaly - maybe you need it later again ...
However - very important is not to overwrite an old QCAD installation. Use a fresh and empty directory for the new installation.
Re: Text not saved
I'm glad to hear that.Galen wrote:I was able to get rid of the problem by loading an old .dwg file.
You are welcome!Galen wrote:Thank you for your help.
