[solved] Attributr "Disappearing"
Whicked
Post by Whicked » Mon Oct 31, 2016 5:31 pm
I'm sure I am doing something silly. I created a block, and in the block editor I gave it 3 attributes, "Name", "Number", and "Current". I assign the tag and the prompt. When I return to my main drawing, the parts not attributes are there, but the attributes don't show. When I reopen it for edit, they are back.
I have other blocks in this drawing with the attributes working.
Re: Attributr "Disappearing"
Post by andrew » Mon Oct 31, 2016 5:38 pm
Please attach your drawing file, so we can help you most efficiently, thanks.
Whicked
Post by Whicked » Tue Nov 01, 2016 4:24 pm
In the attached, 2002-1671 works as I expected, 2002-1681 does not.
block_ex.dxf
(106.57 KiB) Downloaded 356 times
Post by andrew » Tue Nov 01, 2016 4:30 pm
Most likely the attribute definitions have been added after the block was inserted.
Synchronizing the attributes should help:
Block > Attributes > Synchronize Block Attributes
Whicked
[solved] Re: Attributr "Disappearing"
Post by Whicked » Tue Nov 01, 2016 5:48 pm
That di fix it, after I realized I needed to have the blocks selected. Thank you
