I've been using Qcad seamlessly for years, but just today I ran across that weird problem that never had happened before, and I cannot understand.
I had just been casually tinkering with a design, doing all my usual stuff, when all of a sudden Qcad crashed when I tried to draw a simple two points line. I opened the backup file, tried again, crash. And again. And again. I came to notice that the crash happened exactly when, after selecting the two points line drawing tool, I was approaching a very specific point in my sketch, and that very particular one only, and Qcad was normally trying to find an anchorage there. As soon as I disabled all anchorage, crashing stopped. That point is the end of a two points short straight line.
This all seems pretty unexplainable to me. I'm trying to find a trick to bypass that problem, but so far it keeps crashing. Do you have any clue?
[solved] Qcad crashing when trying to find anchorage
Re: Qcad crashing when trying to find anchorage
Thanks for your report. Please attach your drawing file to your post, so we can help you efficiently, thanks.
If you don't know how to attach a file to a post, please refer to this tutorial:
http://www.qcad.org/rsforum/viewtopic.php?f=47&t=3760
Ow. Thanks!
- Fauchon001.dxf
- (161.52 KiB) Downloaded 313 times
Thanks. I'm unable to reproduce the problem here.
Please provide some more details:
- indicate the operating system you are using and the version thereof
- indicate the exact version of QCAD you are using (see Help > About or QCAD > About QCAD
I'm not hugely surprised you can't reproduce it. It's the first time it happens in years. Very odd.
My system is Debian 8.6, and the exact version of QCAD I'm using is 3.11.3.0. Hope It helps
Could you please update to the latest QCAD version (3.15.5) using your personal download link that was sent to you after your last purchase of an update? I will also forward that mail to you again.
Pfff.... shame on me!
Problem solved!
Thanks Andrew!
Problem solved!
Thanks Andrew!
Great, thanks for letting me know.
