Exploding fonts
tamerhirca
Exploding fonts
Post by tamerhirca » Mon Dec 19, 2016 2:04 pm
Hi;
whenever I explode texts, the shapes consist of numerous arcs and lines. Even if I convert them to polylines, manufacturing these objects is quite problematic; they do not behave as continuous lines. Is there a specific font appropriate for machining or a method to convert them more effectively ?
Thanks.
Tamer
Re: Exploding fonts
Post by andrew » Mon Dec 19, 2016 2:13 pm
What shapes do you wish to get (if not arcs, lines or polylines)? You might want to attach your drawing file or a screenshot to explain your problem in more detail, thanks.
tamerhirca
Re: Exploding fonts
Post by tamerhirca » Mon Dec 19, 2016 2:50 pm
Hi;
I am happy with arcs, lines and polylines. The problem is that one letter once exploded consists of 60-70 even more of such entities. When cutting long texts with laser this creates a slight performance issue. I wonder if there is a font better suitable for such purposes (ie exploding to less segments)
Thanks.
Re: Exploding fonts
Post by andrew » Mon Dec 19, 2016 4:56 pm
You can try Draw > Polygon > Simplify to simplify the polygons after exploding the texts. You can enter the maximum angle deviation at the top to simplify more or less aggressively.
