Unable to Read Layers in Some .dwg Files
I have been unable to view some layers of some .dwg files that were sent to me. I assume the drawings were created on AutoCAD, but I don't know that for sure. I have another CAD package (TurboCAD) that opens all the layers (but I much prefer QCAD Pro 3). I sent the files to a moderator on one of these QCAD forums and he suggested I contact Andrew for further assistance. The file(s) are too large to attach here.
Re: Unable to Read Layers in Some .dwg Files
Hello alcpe,
How big they are? Would it work via PM or e-mail?alcpe wrote: The file(s) are too large to attach here.
Two files, about 1MB each. But just one file will be sufficient to see the issue.
That should work with pm. Please send them to me and I will have a look. If you are facing difficulties via PM I will give you my e-mail.alcpe wrote:Two files, about 1MB each. But just one file will be sufficient to see the issue.
Did you receive the PM. It just said PM file limitation is 256 kb. My files are too large for PM.
Hi alcpe - thank you for the files via e-mail.
I think the problem is based on 3D information in the original drawing. QCAD is 2D and not able to handle 3D.
I tried to get rid of the 3D information (Flatten Drawing to 2D) but wasn't successful. Sorry but maybe Andrew has additional thoughts on this.
Well, perhaps part of the problem is a 3D issue. But one layer not visible in QCAD is the drawing's border; another invisible layer just shows room numbers (i.e. text only). I wouldn't think those layers are 3D.
Will Andrew review this discussion?
The TurboCAD software I have that can view all layers of the files is 2D only.
I particularly need these 2 layers to be visible: A-ANNO-RMNM-E and A-ANNO-IDEN-E.
I doubt that but I can't say it for sure. If I check your original drawing in the Autodesk Viewer then I've two results:alcpe wrote:Well, perhaps part of the problem is a 3D issue. But one layer not visible in QCAD is the drawing's border; another invisible layer just shows room numbers (i.e. text only). I wouldn't think those layers are 3D.
3D - what shows what you are looking for ...
... and 2D - which will ignore the same layer like QCAD did.
What I would try in your position is to open this drawing in TurboCad and try to get rid of this 3D information. Then save the drawing (try dwg, dxf etc) under a new name and check it again in QCADalcpe wrote:The TurboCAD software I have that can view all layers of the files is 2D only.
I'm sure.alcpe wrote:Will Andrew review this discussion?
Thanks for your help. TurboCAD is difficult (for me) to use (one reason I prefer QCAD). I wish I knew how to convert the 3D layers into 2D. My TurboCAD may not be able to do that since it is a 2D design package.
Please send the file by e-mail to info AT ribbonsoft DOT com. Without the file, this is a wild goose chase for me as well. Thanks.
alcpe: Could it be that you are looking for the layout / paper space?
- View > Block List
- Doubleclick on "FullsizeD (2) (*Paper_Space)"
- View > Block List
Wow! THANK YOU!!!
Andrew, there is still one layer I am unable to see in QCAD: A-FLOR-PATT-E. I don't really need that layer, but I'm curious why that seem to be the only layer not visible in QCAD. Thanks much!
