Hello everyone,
I seem to have a little problem saving a file: qcad gives a warning that it cannot set the textsize to that value (see attachment)
What can be the problem and how can I resolve this?
Thanks, Stephan
Textsize error
Textsize error
- Qcad foutmelding.PNG (112.49 KiB) Viewed 5195 times
Re: Textsize error
The TEXTSIZE variable in your DWG file has an invalid value which is not accepted by the Teigha DXF/DWG library when saving. If you can attach / send the file, I can fix that for you. Or if you let me know what platform you are on, I can give you access to a development snapshot with that problem fixed.
Re: Textsize error
Hello Andrew,
tried to send you the file but it`s too big and cannot be attached to the message...
What could I try now?
Stephan
Stephan
Re: Textsize error
Hello Andrew,
forgot to mention the platform I work on. Mostly that would be windows 10, and occasionally on
Linux (Manjaro).
Stephan
Linux (Manjaro).
Stephan
