[Solved] Ortophoto layer no longer visible
Jmvidalribas
Post by Jmvidalribas » Fri May 19, 2017 9:09 am
I use QCAD Pro 3.12.8
I received by email and opened a .dwg file (31KB) with GIS information (Ortophoto)
I created additional layers and worked with them smoothly.
At some point, without noticing it because the ortophoto layer was de-selected, I could not see this layer again.
I opened the original file with the same result: no longer visible.
I have used the auto-zoom to center the contents with the same result.
I guess it is something about configuration in my QCAD desk. I am feeling rather stupid!
Any help from your side will be appreciated.
Thanks in advance.
Re: Ortophoto layer no longer visible
Post by andrew » Fri May 19, 2017 9:14 am
For all support requests, please:
- indicate the operating system you are using and the version thereof
- attach original drawing files (DXF, DWG, ...) if appropriate
- include screenshots if appropriate
Jmvidalribas
Post by Jmvidalribas » Fri May 19, 2017 10:54 am
OS is Windows 8.1
Attached you fill find the original file.
Ortofotomapes 2015.dwg
(31.07 KiB) Downloaded 251 times
Post by andrew » Fri May 19, 2017 11:20 am
Layer ortofoto contains two image references to image files:
\\Desktop-rikpa90\bústia\Mis documentos\PLANOLS\Blanquet\Mas Ombert\Arrossars Z (1 - 8)\URMPNTWD.jpg
and:
\\Desktop-rikpa90\bústia\Mis documentos\PLANOLS\Blanquet\Mas Ombert\TRPVMRLN.jpg
Please make sure these image files exist either in that location or in the same folder as your drawing file.
Jmvidalribas
Post by Jmvidalribas » Sat May 20, 2017 8:59 am
Done! :lol:
Thank you very much for your technical support.
This post can be closed.
Jm
