Moving/copying causes lines to lose their linetype property
JSHUK
Post by JSHUK » Thu Jun 08, 2017 10:08 am
The title says it all, really. I've noticed that, when moving and/or copying an entity or group of entities, that for example, a line which has been given a "hidden" appearance, reverts to the basic continuous linetype after the move/copy function has taken place.
Using QCAD Pro 3.17.1.0 (3.17.1.1) on 64-bit Windows 7 Pro machine.
Re: Moving/copying causes lines to lose their linetype property
Post by andrew » Thu Jun 08, 2017 10:16 am
Make sure the option "Use current layer and attributes" is NOT checked in the options tool bar (or in the dialog if you are using a dialog):
Screen Shot 2017-06-08 at 11.14.48.png (19.32 KiB) Viewed 5769 times
Screen Shot 2017-06-08 at 11.16.23.png (45.1 KiB) Viewed 5769 times
JSHUK
Post by JSHUK » Fri Jun 09, 2017 8:59 pm
Thanks, Andrew. That's where I was going wrong. All working as I expect it to, now.
