Dimension Tolerances
jdi000
Post by jdi000 » Sat Jul 22, 2017 1:59 pm
When opening a dxf or dwg not created in QCAD, the tolerances are missing from dimensions. Is this expected behavior of QCAD?
The Teigha Viewer displays these correctly.
Jason
Win 10
QCAD 3.15.5
ex1.dxf
(165.99 KiB) Downloaded 347 times
Jason
Win 10, Win 7
Re: Dimension Tolerances
Post by andrew » Sat Jul 22, 2017 3:02 pm
QCAD supports dimension tolerances as part of the label formatting, but not as defined by this file as an individually assigned dimension style, that's correct.
jdi000
Post by jdi000 » Sun Jul 23, 2017 2:38 pm
Thanks, Any chance that QCAD will be able to support industry standard tolerance and dimension styles in the future?
Jason
Jason
Win 10, Win 7
